SUBARU Recommended Materials -Warranty/After Warranty cars
Legacy Impreza Forester Tribeca
SOHC model 3.0 L and DOHC turbo, DOHC Non-turbo model, SOHC, 1.5 L DOHC model Turbo model, DOHC, 2.0 DOHC Non-turbo model, SOHC Turbo model, DOHC DOHC
2.0 L SOHS
2.5 L SOHS 2.0L DOHC turbo
3.0L DOHC
2.0LDOHC 2.0 L, 2.5 L, 1.5 L 2.0 L, 2.5 L 2.0 L, 2.5 L 2.0 L, 2.5 L 3.0 L
LUBRICANTS
Engine oil Mobil/Motul products ( warranty/after warranty cars) Mobil 1 0W-40 , Mobil 1 5W50*
Mobil 1 Synt S 5W-40**, Mobil 1 Super FE 5W-30***
Motul 8100 X-lite 0W30*, Motul 8100 Eco-Nergy 5W30*,
Motul 8100 X clean 5W40 *, Motul 300V Power Racing 5W40,
Motul 300V Chrono 10W40**
Manual transmission oil Recommended 75W-90 75W-90 75W-90 75W-90 75W-90 75W-90 Not applicable
Mobil/Motul products (warranty/after warranty cars) Mobilube 1 SHC 75W-90 Mobilube 1 SHC 75W-90 Mobilube 1 SHC 75W-90 Not applicable
AT front differential gear oil Recommended 75W-90 75W-90 75W-90 75W-90 75W-90 75W-90 GL-5
Motul Gear 300 75W90 Mobilube 1 SHC 75W-90
Rear differential gear oil Recommended 75W-90 75W-90 75W-90 75W-90 75W-90 75W-90 GL-5
Mobilube SHC LS 75W-90 - для самоблокир-ся дифференциалов
Motul Gear 300 75W90 Mobilube SHC LS 75W-90 - для самоблокирующихся дифференциалов
Motul Gear 300 75W90 Mobilube SHC LS 75W-90 - для самоблокир-ся дифференциалов
FLUID
AT 4AT Recommended SUBARU ATF
(K0410Y0700) SUBARU ATF
(K0410YO700) SUBARU ATF
(K0410Y0700) Not applicable
Alternative SUBARU ATF
5AT
(K0410Y0700) - - SUBARU ATF
(K0410Y0700)
(K0410Y0700)I - - SUBARU ATF
(K0410Y0700)
Power steering fluid Recommended DEXRON III DEXRON III DEXRON III DEXRON III
Mobil/Motul products (warranty/after warranty cars) Mobil 1 Synthetic ATF*
Motul Dexron III Mobil 1 Synthetic ATF*
Motul Dexron III
Brake fluid Recommended FMVSS No. 116 DOT3 FMVSS No. 116 DOT3 FMVSS No. 116 DOT3 FMVSS No. 116 or DOT4
Mobil/Motul products (warranty/after warranty cars) Mobil Brake Fluid
Motul Brake Fluid DOT4 Mobil Brake Fluid
Clutch fluid Recommended FMVSS No. 116 DOT3 FMVSS No. 116 DOT3 FMVSS No. 116 DOT3 Not applicable
Motul Brake Fluid DOT4 Not applicable
COOLANT
Coolant Recommended SUBARU coolant
(000016218) SUBARU coolant
(000016218)
Alternative Non-amine type Non-amine type Non-amine type Non-amine type
Mobil/Motul products (warranty cars) Mobil Antifreeze Extra (G48)** Mobil Antifreeze Extra (G48)** Mobil Antifreeze Extra (G48)** Mobil Antifreeze Extra (G48)**
Mobil/Motul products (after warranty cars) Mobil Antifreeze Extra(G48)** Mobil Antifreeze Extra(G48)** Mobil Antifreeze Extra(G48)** Mobil Antifreeze Extra(G48)**
Water for dilution Recommended Distilled water Distilled water Distilled water Distilled water
Alternative Tap water (Soft water) Tap water (Soft water) Tap water (Soft water) Tap water (Soft water)
REFRIGERANT
Refrigerant Recommended HFC134a HFC134a HFC134a HFC134a
Alternative None None None None
Compressor oil Recommended DENSO OIL 8 DH-PR ZXL200PG DENSO OIL 8
Примечание: Данные рекомендации разработаны совместно компаниями ООО « Субару Мотор » , Exxon Mobil и Motul
с учетом рекомендаций производителя автомобилей Subaru - компании Fuji Heavy Industries Ltd. и опыта эксплуатации автомобилей Subaru на территории России и Белоруссии.
* и * Эти типы масел могут быть использованы только в двигателях без наддува .
** Данный тип масла может быть использован при температурах не ниже -35 С
** Данный тип масла может быть использован только в двигателях без наддува с интервалом замены 10 000 км . и менее.
*** Данный тип масла может быть использован только в двигателях без наддува с интервалом замены 10 000 км . и менее , при температурах воздуха менее 25 градусов Цельсия , т.е. исключая летний период эксплуатации.
* Соответствует Dexron III (кроме того, это полностью синтетическое масло)
** Справедливо при полной замене охлаждающей жидкости.
Конфиденциальный листок Усера. Правда за 2006 год.
Почитал и задумался...
Почему его они скрывают.
Работникам Усера просьба не беспокоиться-сотрудник уже не работатет там.
