Правильная направляющая воздушного потока
tommy
21 Авг 2009
12
www.yousuba.ru
интересно, если сделать другую напрявляйку вместо стока, будет ли заметный результат?:)
Oleg B
10 Янв 2008
808
309
Kiev
там регится предлагают, чтоб картинки посмотреть
А есть ещё не зарегистрированные там? Полезный ресурс, большинство в картинках.
"This is an under $100.00 mod to hold you untill you can afford a larger (STI) intercooler and hood scoop/diverter.
Fabrication skills are a must! All parts can be purchased at the local hardware store, except the fans and cords.
Fans and cords can be found by doing a search for muffin fans. Mine came from a surplus vendor in NY.
Parts used to mount fans were 1/2" aluminum angle, pop rivits, 1" aluminum flat stock (for front bracket).
To keep air born matter out of fans, I used fiberglass window screen, between hood scoop and diverter(held in with duct tape).
RTV could also be used as glue, if you take the time to let it dry.
Another picture of diverter
This is where I located the on/off switch.
Ash tray was removed and power was tapped from accessory terminal.
A bonus is the switch is illuminated when lights are on.
This is a photo I ment to post with first message.
These fans are rated at 106 cfm at 3000 rpm.
When you hold your hand under the intercooler, a positive air flow can be felt.
As for performance increase... I would rather say: you keep the cool morning performance, in the hot afternoon.
Combating the "heat soak" can only be a good thing.
Also, most of my driving is city.
To date (5 months), I have had no problems with this reversable mod.
The corner wire-tie hold downs do wear thru, but if you open the hood enough, you will spot this. Front brackets hold set up in place.
Did I mention the whole set up is padded with 3/8" peel & stick foam (to prevent rattles).
Вот такие извращения бывают....
Реакции: andyta
Altaiz
Партнёры Клуба
В пробке может и лучше чем без них, а на скорости они будут мешать обдуву естественному или они на постоянку крутят?)
Мне кажется чем тупо воздух гонять в подкапотном таким методом, лучше орошайку все же.
Scor66
9 Ноя 2007
3,748
282
Texas
Согласен с оратором. Если ставить вентиляторы, то лучше снизу, чтоб втягивали.
Миша
28 Авг 2008
158
35
КИЕВ
товарисчи, орашайку спиртовую аккуратно использовать нада.
и после каждого "орошения" закусывать, а то так надышаться парами можно, что к концу поездки и из машины не выйдешь:sarcastic:
MSTiFK8R
6 Апр 2009
1,427
181
товарисчи, орашайку спиртовую аккуратно использовать нада. и после каждого "орошения" закусывать, а то так надышаться парами можно, что к концу поездки и из машины не выйдешь
ага, разумная доля спирта в этой смеси - 20%
эффективность охлаждения повышается примерно ВДВОЕ по сравнению с чистой водой! (вы спирт на руку не проливали ? :) )
Миша
28 Авг 2008
158
35
КИЕВ
тезка, без обид, то была просто флудильная шутка в правильной и интересной теме.
все кто в школе учился поймут природу процесса охлаждения именно спиртово-водным расствором.
зы
но надышаться все равно можно:p
MSTiFK8R
6 Апр 2009
1,427
181
огурчики в бардачке надо будет возить, как доделаю :)))
Ruslan_
20 Авг 2009
146
правильные жабры и обратные ноздри, конечно, помогут снизить подкапотную температуру
но эстетически это мимо моего восприятия :)
А по мне так ничего выглядит:
если еще задвижку снизу придумать (летом открыл, зимой закрыл) Где бы купить такую:?:
Ruslan_
20 Авг 2009
146
Oleg B
10 Янв 2008
808
309
Kiev
To MSTiFK8R :
Миша, на родных и тюнинговых направляющих сбоку есть сетка для "выдувания" горячего воздуха от турбины и верхней части даунпайпа. Как у тебя это реализовано?
И ещё: какие уплотнители между твоей направляющей и интеркулером?
