Об отсутствующих опциях на европейской версии атмосферника, и присутствующих на американце.
TO
REPRESENTATIVE DIRECTOR OF THE BOARD
PRESIDENT & CEO
MR. IKUO MORI
Dear Sir,
I’m writing to You on behalf of the Russian Subaru Forester Club. We are more than several thousands happy owners of Foresters starting from original MY'98 ones and finishing with brand new MY'07 versions. All of us think this car is one of the best ever, due to its unique combination of good off-road abilities with excellent on-road behavior. Please answer a few questions about difference between European Forester 2.0X and North American (NA) Forester 2.5X:
1) In NA version You install Engine: 2.5L Single Overhead Cam (SOHC), 16-valve, horizontally-opposed, 4-cylinder SUBARU BOXER engine, Electronic Throttle Control and i-Active Valve Lift System. Why are you not installing the same engine for the European version? We would like to buy it in the Russia.
2) In NA version You install Brakes (rear): Solid discs (266 x 10 mm), single piston calipers. Why are you not installing the same brakes for the European version? We would like to buy it in the Russia. In European version You install only drum brakes.
3) In NA version You install Suspension Rear: Strut-type with internal rebound spring and parallel link. Antilift geometry. Rear stabilizer bar. Why are you not installing the same suspension for the European version? We would like to buy it in the Russia. We like a suspension without self-leveling feature. The reason in our severe winter climate.
4) In NA version You install 120-watt 4-speaker audio system with 6-disc in-dash CD changer and MP3/WMA player and Auxiliary audio jack for portable media players. Whether there is any reason of absence of such audio system on the European version? We would like to buy it in the Russia very much with Forester.
5) In NA version You install Antitheft security system with answer-back electronic chirp and glass shock sensor, and Keyless entry system with answer-back electronic chirp. Why are you not installing the same security system in European version, with standard Engine immobilizer system?
6) Very much we hope, that HID headlights and Limited-slip viscous type rear Differential will be accessible, as an option on all European models.
All the listed options can be established at will of the client, but we very much hope, that the opportunity will order them in us.
Thank You in advance for Your answers. Excuse, that we disturb you, very much we hope that will not disregard opinion of your clients.
Russian Subaru Forester Club:
http://www.forester-moscowclub.ru
TO
PRESIDENT & CEO
MR. IKUO MORI
Dear Sir,
