Новости о Forester
Вам нравится Subaru Forester tS STI 2011?
  • Всего проголосовало
    277
Энт
Администратор,
20 Ноя 2006
14,994
1,845
РУСЬ
Обратите внимание на цену :) :) :) : http://cgi.ebay.com/ebaymotors/2009...207681692QQcmdZViewItem?hash=item190207681692
P.S. Костян бери!!! L.L.Bean!!!! Красненький, как ты любишь :) Sells to:Worldwide!!!! :???: Всего то...
Advizer
25 Дек 2007
14
Касательно комплектаций (информация с Subaru Global), скорее всего, для европейского рынка
[Line-up]
2.0X: Basic model with excellent safety, functionality, and fuel efficiency
2.0XS: Advanced model with a balance of the Forester’s superior basic functions
2.5XT*: High performance crossover with rich spaces and functionality
*Distribution of 2.5XT is limited to some distributors.
■ Transmission
Electronically controlled 4-speed automatic transmission
All models are equipped with the SPORTSHIFT 4-speed AT gear selection. Selector lever operation has been enhanced by the redesigned selector lever positions and the use of roller bearings. In addition, densification of the hydraulic pressure required for AT for engine torque has optimised the required hydraulic pressure and reduced torque on the AT oil pump. Low-viscosity ATF was newly developed to improve fuel efficiency.
5-speed manual transmission with dual-range
Driving performance and feeling have been improved by reducing friction among transmission part assemblies.
Change in engine position
An expanded road clearance further improves the drivability of the vehicle, while low centre of gravity is attained by mounting the engine low in the vehicle. This allows outstanding vehicle stability even in an SUV.
Active Torque Split AWD (in models with automatic transmission)
Basic torque distribution to the front and rear wheels controls the hydraulic multiple-disc clutch according to driving conditions. In addition, in-vehicle LAN is used to detect wheel speed, engine output, and VDC conditions in real time, precisely analyse surface and driving conditions, constantly control optimum torque distribution according to coordinated control with VDC, and maintain superior traction and vehicle stability.
Centre differential AWD with viscous LSD (in models with manual transmission)
Basic torque distribution to the front and rear wheels is set by the centre differential with bevel gears, and differences in speed are absorbed/suppressed by the viscous LSD, achieving continual driving stability.
■ VDC (Vehicle Dynamics Control)
VDC, which assists the superior driving stability of symmetrical AWD, is standard on all models. Fed by information gathered by sensors that monitor vehicle and road conditions for VDC control (engine control and brake control to prevent lateral slipping), TCS control (engine control and brake LSD for traction control), and ABS control (anti-lock brakes) for driving stability.
■ Brakes
Four-wheel disk brakes...
Specifications 2.0X/2.0XS 2.5XT
Engine
Bore x Stroke, mm 92.0 x 75.0 99.5 x 79.0
Capacity,cc 1,994 2,457
Compression ratio 10.2 8.4
Fuel system Multi Point Sequential Injection
Fuel tank capacity, lit 60
PERFORMANCE MT/AT
Max. output (DIN)
kW(PS)/rpm 110(150)/6,000 169(230)/5,200
Max. torque (DIN)
Nm(kgfm)/rpm 196(20.0)/3,200 320(32.6)/2,800
Max. speed
(in top gear) km/h 185/184 214/207
Acceleration
(0-100 km/h) sec. 11.0/12.7 7.1/7.9
Fuel consumption
lit./100 km
Urban 10.9/11.2 14.4/14.5
Extra-urban 7.0/6.9 8.2/8.2
Combined 8.4/8.4 10.5/10.5
DIMENSIONS & WEIGHT
Overall length, mm 4,560
Overall width, mm 1,780
Overall height, mm 1,700
Wheelbase, mm 2,615
Track front, mm 1,530
Track rear, mm 1,530
Minimum road clearance
(at kerb weight), mm 215 225
Seating capacity
persons 5
Kerb weight, kg 1,475/1,495 1,520/1,535
High/Low ratio
1.447 (2.0X 5MT)
CHASSIS
Minimum turning
circle at tyre
(radius), m 5.3
Front Ventilated disc brakes
Brakes
Rear Disc brakes
Tyres 215/65R16 225/55R17
rps64
4 Май 2007
469
Moscow
из вина видно как теперь кузов называется (американский?): SH6
Xurma
4 Май 2007
961
94
оттуда
Нисколько... FHI по сравнению с Тоетой конечно мелкосерийное производство, но не настолько, чтобы персонально для покупателя собирать авто, как вейрон какой-нибудь.... и тем более не автоваз, где можно "попросить" собрать отдельный экземпляр на мощностях ОПП....
Хотите такую стиху - дешевле выйдет уехать в японию на 6+ месяцев, брать тама стиху, тащить сюда и перекидывать....
Субару делает интересней(это должен знать каждый фэн марки):
Каждый день с завода сходит определенное кол-во авто, вроде как одинаковых, но только "вроде как". Одни и те же авто, выпускаясь в разные месяцы, могут иметь абсолютно разный вес и мощность(хотя в документах все может выглядеть одинаково). Лично я видел такие варианты. На примере СТИ импрезы одного и того же года - несмотря на абсолютный сток, одна импреза всегда уезжала от другой, причем порядочно. Мощность не измерялась, но при весовом контроле(!) оказалось, что одна машина весит почти на 100кг меньше другой.
На фото не сти, а один из вариантов КС для американского рынка. СТИ в попонии(почти новый СГ-9) стОит порядка 17-18тыщ$(06-07года, к примеру). По приезде такое авто(непроходное)будет стОить порядка 35 со всеми налогами.
Алексей Лопатин
18 Ноя 2006
1,201
Москва, Мещерский лес
Получается с коэффициентом 2...?
Wolf
8 Май 2007
708
Kiev
Сегодня был на Усенко ( Мега- Моторс - уже УА Холдинг) - оф диллер вообщем :D Насчитал 8 новых форей :D Все 2.0 в разных комплектациях! и цветах! В живую мне оч понравился, компактный очень и не большей :D Вообщем, мне нравится! у нас 27-28 марта презентация, на следующий день уже обещают, что можно будет в салонах щупать и покупать и т.д. :D
З.Ы. Сорри за качество, фоткал моб. телефоном :eek:
Wolf
8 Май 2007
708
Kiev
Кстати, на самой дешевой комплектации теперь черные сталюки с колпаками(неплохо смотрится), а раньше были серебристые сталюки! И еще из видимых новшеств - это дворники без каркаса :D По модному, так сказать :)
Hardex
17 Янв 2008
77
ОБЪВИЛИ ЦЕНУ на Форестер 2009...
Только что звонил манагер У-Сервиса, сказал цены на Форик 2009: :-(
2.5 XT AT full option = 1303600 руб., т.е. $ 55 000 :sad: :-( :shock:
Кто что думает по этому поводу???
Sink
31 Авг 2007
177
из леса вестимо
Это по курсу на 25.03.06 составляет чуть более 46 тыс американских денег. Топовая версия в этот период стоила 45 тыс.
С уважением
Dreago
5 Июл 2007
1,269
10
но ведь там стекла дверные в рамках! Это ж взбесит!
Geser
18 Мар 2008
604
Южное Бутово
Блин, точно в рамках. Еле нашел фото с открытой дверью.
Это засада. Ну на хрена так портить автомобиль.
Мне он только начал нравиться. :-o
Azatot
15 Янв 2007
891
19
а где турбо?
