Γεια σας από την Ελλάδα
stolis
23 Сен 2010
Greece
The last engine, had a broken carrillo rod, so it completely destroyed.
The new specs are:
Close deck 2.5 block with arrow rods, je pistons, acl bearings
sti 06 motor heads impoved
Rotated garrett 3076 0.82 AR turbo
cobb 76mm exhaust with custom downpipe
Custom uppipe
supersprint header
dgv delete
perrin air intake
avcr boost controller
Coyo radiator
Setrab oil cooler
Greddy f/m intercooler
simak
15 Дек 2008
1,224
159
Моск. Обл.
The new specs are:
Custom uppipe
supersprint header
dgv delete
perrin air intake
Coyo radiator
Setrab oil cooler
something about 400HP again?
stolis, you can see the detailed information about the Winter Subafest in the files attached below.
We sincerely hope that you will be able to visit us.
Best wishes!:idea:
Moderator
Stolis, you're best as always)
Is it enough comfortable to drive in the snow with your big turbo? how about boost lag?
Did you noticed that with front lsd forester like to jump out from the rut in the snowy road? Because I did, with my suretrac in front usually I hardly could stay direct on the rut in the snow)
stolis
23 Сен 2010
Greece
Thank you my friend.;-)
My lsd is not suretrac, is helical that is more friendly. I don't have any problem with that, it is super....
That turbo is unbelievable. With 2000-2500 with 2nd gear i had enought boost for oversteering in close turns.
Even with 3rd gear and 2500-3000 i have the power any time.
I did not expect this.:lol:
alexnote76
10 Фев 2012
Ярославль
Stolis, видеоролики на youTube от пользователя SUBA400 поставили точку в моих метаниях по выбору своего следующего автомобиля. Во многом, благодаря ему я купил свой FORESTER и вступил в этот клуб, стал счастливее вконце концов. Спасибо.
Stolis, βίντεο στο YouTube από SUBA400 θέσει τέρμα στην ανήσυχο μου κατά την επιλογή του επόμενου οχήματός τους. Σε μεγάλο βαθμό χάρη σ 'αυτόν αγόρασα FORESTER του και τέθηκε σε αυτό το κλαμπ, πιο ευτυχισμένοι vkontse άκρα. Σας ευχαριστώ.
