Наш одноклубник Maxus купил такой датчик.
Цена, приблизительно будет 50$ за парктроник и доставка при 10 человеках где то 12-15$.
Здесь его продают за 4500 рублей http://www.uniaks.ru/index.php?loc=main&id=91
Отчет об установке таких датчиков Maxus читаем здесь: http://forester.club/viewtopic.php?t=2375&postdays=0&postorder=asc&start=75
Здесь дополнительные фото от Maxus: http://picasaweb.google.ru/maxim.emm/OqnSfD
За 50$ плюс доставка 120$ DHL. На одного доставка дороговата. А вот если совместно, то вроде и ничего
Характеристики (обратите внимание на расстояния до препятствий):
LCD Display Parking Sensor System
Model: PS-LC3B17-8
This model consists of:
1. 2 ECUs (Electronic Control Unit): 1 for rear and 1 for front detection.
2. 1 Alarm unit: Digital LCD Display with built-in buzzer & cable
3. 8 Ultrasonic sensors with cable
4. Accessory: User’s manual, double-sided adhesive tapes, quick-on sscable clips & 1 drill bit
Overview:
4 sensors are installed in rear bumper and the other 4 sensors in front bumper. The ECU for rear sensors gets power from reversing light and the ECU for front sensors gets power from the battery and the brake system.
Once the engine is started, front sensors begin to work automatically for 30 seconds. And after each brake, front sensors work for 30 seconds. During car reverse, all the 8 sensors work simultaneously.
The LCD display installed in front of drivers shows the direction of obstacle and the distance from bumper to obstacle.
Features:
1. Top sensitivity: a person around 1.3~1.7m from the bumper or a
ss normal cable can be detected with fast reaction.
2. Min. distance: 15cm for front and 22cm for rear detection
3. 0°viewing angle of jitter-free LCD display with minimal false alarm
4. Audible alarm volume adjustable: high, low and mute. Audible alarm ss generated by the 2 rear central sensors starts from 1.7m behind, 1m ss for the 2 rear side sensors, 0.5m for the 2 front central sensors, and ss 0.3m for the 2 front side sensors. It’s a perfect eco-friendly design.
5. Workable at very low temperature condition: -35 ℃
6. Latest design of fashionable shapes.
7. With high stability based on reliable design and the use of high-
ss quality components, so the system typically outlives the vehicle.
and more...
Technical data:
1. Working Voltage: 10-28V
2. Max Power: 10W
3. Max Display Distance: 2.5M
4. Min Display Distance: 0.15M
5. Max Alarm Distance: 1.7M
6. Alarm Volume: mute, 70 & 90dB (at 1.0M) xxadjustable
7. Working Temperature: -35 - +80℃
Здесь буду постить желающих:
1. Энт +1
2. Woodman +2
3. }{удожни|{ +1
4. Уралец +1
5. Scor66 +1
6. Metsaisa +1
7. Артём +1
8. Rand +1
9. FREDp38 +1
10. DanGer
Итак 10 штук уже есть ))))
Постите сюда о желании приобретения.
P.S. Зима скоро....
Model: PS-LC3B17-8
Overview:
Features:
and more...
Technical data:
2. Max Power: 10W
1. Энт +1
2. Woodman +2
3. }{удожни|{ +1
4. Уралец +1
5. Scor66 +1
6. Metsaisa +1
7. Артём +1
8. Rand +1
9. FREDp38 +1
10. DanGer
P.S. Зима скоро....
