Performance Gauge Pack?
tools
17 Окт 2006
453
A pressure gauge measuring the manifold pressure can be fitted to give the driver an indication of how hard the engine is working and can be used to achieve maximum momentary fuel efficiency by adjusting driving habits: minimizing manifold vacuum increases momentary efficiency. A weak manifold vacuum under closed-throttle conditions shows that the butterfly valve or internal components of the engine are worn, preventing good pumping action by the engine and reducing overall efficiency.
